Extending Amazon Eero
Message 3 of 3
My wifi does not reach much further than the room the eero is in. What wallet-friendly wifi extenders work well with Amazon Eero?
Chris-TalkTalk
Message 1 of 3
Hi katbrooks1991,
How are you getting on? I can see that Keith has kindly offered to help if you still need assitance
Message 2 of 3
Don't spend any money yet, it is important to see if this is purely a signal strength issue, or if it is caused by WiFi interference, with which I can help a lot.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
