on 06-05-2024 11:44 AM
I have had the Huawei HG633 router for nearly 10 years. Whilst the fibre broaband speed coming into the house meets what Talk Talk guarantee, I experience WiFi inconsistency most days, with devices dropping connection, which requires frequent reboots of the old router to re-establish the WiFi connection.
I can see you offer a superior router to your new customers. As a customer of almost 18 years standing, could my old router please be upgraded? Thank you.
DP
Friday
Thursday
No worries @KeithFrench thank you , will report back when it arrives
Thursday
First off @delypo lets wait & see which unit you actually get.
Thursday
That's great, thank you @Debbie-TalkTalk
@KeithFrench when the extender arrives, based on your assessment of the results I provided, where do you recommend I position it?
Thursday
Hi delypo
No problem 🙂
You should receive this within the next 48hrs.
Thursday
Thank you again @KeithFrench and @Debbie-TalkTalk for your help. I will look forward to receiving and testing the Wifi Booster to see if this improves speeds throughout the house on the 2.4 GHz frequency.
Thursday
Thursday
Hi @Debbie-TalkTalk @Michelle-TalkTalk @Chris-TalkTalk
This customer has a bigger house than some would really benefit from a Sagemcom FAST266 WiFi Booster to go with his 5364/5464 router. Would this be a possibility?
Thursday
Hello @KeithFrench
The router is situated at the front of the house, on its own cupboard shelf, in the lounge with no other electrical equipment in its immediate vicinity.
Moving from that room to the other two rooms mentioned there are no large expanses of metal nor any fish or water tanks.
Thursday
Hi @delypo
Your problem was easy to detect from those screenshots, but before recommending a solution, please can you tell me where the router is located. Is there any other electrical equipment near it. Enroute from there to the three rooms that you mention, are there are any large expanses of metal or any fish or water tanks in the way?
Thursday
That's good to know, thank you @KeithFrench and there's no rush - appreciate your help in this.
Thursday
Hi @delypo
I have them all now. It is really helpful that you have thought to get them from all three locations. I will try & look at them a bit later this afternoon.
Thursday
Wednesday
No problem @delypo
Wednesday
Thank you @KeithFrench, will get back to you over the course of the next few days.
Wednesday
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
Wednesday
Hello @KeithFrench
Thank you for your response. The replacement router is the Sagem Wi-fi Hub 2 Fast 5464. This has been in situ from Fri 10th May and we have seen no intermittent drop outs and the light has remained a solid white. If we use the laptop wired, then it performs well at a speed of 67Mbps.
Any help you can give to try and improve our 2.4 GHz WiFi speed around the house would be appreciated and so we would be grateful to receive your guide and any support you can give. Thank you.
Wednesday
Hi @delypo
@Michelle-TalkTalk has asked me to help you to try & improve your 2.4GHz Wi-Fi speeds. I assume that your replacement router is the Sagemcom FAST5364?
Wednesday
Thanks for confirming. @KeithFrench - Would you be able to offer any advice on this please?
Tuesday
No, they are older devices and will only connect at 2.4 GHz.
