on 06-05-2024 08:48 AM
I have Fibre65 and the Talk Talk Hub2 router.
I am trying to set up some port forwarding.
The routers interace, is not the greatest and its very slow. BUT I have to use this router as I have a VoIP landland.
All I want to do is a port forward as in the attached image, but its not letting me & its not telling me why.
Can anyone please advise ?
Sunday
The router is no more locked down than any other 5464. Have you tried a factory reset?
Sunday
Thanks very much for testing my rule.
This is the first port forward I have done, so there is nothing conflicting with it.
I will try to contact TalkTalk, as either my router is locked down or there is an issue.
Thanks for all the help
on 07-05-2024 10:50 AM
I have just tested your rule on my 5464 & it not only was accepted, but it worked the first time. Have you created other rules that use the same ports for any other device or IP address?
on 06-05-2024 09:19 PM
Hi. Thanks for the reply. It is actually a FAST 5464-1.T4 running SG4K100174 GUI version: 5.100.1.
THANK YOU
on 06-05-2024 10:38 AM
I assume that this is the Sagemcom FAST 5364 & not the Hub 2 (FAST 5464)? If so what is the hardware revision of it?
