on 09-05-2024 02:15 PM
Hi there, I've recently started experiencing connecting through Fortinet VPN from my home network (Talk Talk Fibre 65) when connecting through mobile data doesn't seem to have this problem. is this a know problem from Talk Talk wifi and if so, are there any known solutions, please?
Friday
Hi DarrenW66
Thank you 🙂
Friday
My apologies, I just added that now.
Thank you
Friday
Hi DarrenW66
Please can you add your TalkTalk account number to your Community Profile, I can then send the replacement router for testing.
Friday
Hi Michelle, yes please, let's give that a go. I'll send it back if it doesn't help.
Thank you
Friday
Hi Darren,
I'm sorry to hear this. Would you like us to send a replacement router for testing purposes to rule this out?
Thursday
Ah, OK, I guess I'm not then. As I indicated, I wasn't sure. My apologies
Thursday
It is just that your screenshot of the configuration you gave me, clearly shows that you are not using any certificates.
Thursday
Hi again Keith. The Windows update hasn't helped, unfortunately. Also, what appeared to be working by using the VPNBook connection is also no longer working. I have to hot spot on my mobile phone data connection to get this to work at the moment.
Just coming back to your previous question(s):
'The Forticlient contacts the server and performs some encrypted exchange. Are you sure that you don't need to use any certificates? Did this ever work to your employer's VPN server?'
I'm at the limit of my technical expertise on this matter at this point. However, I do believe certificates are used (I seem to recall something about certificates coming up occasionally when connecting the rdp). And yes, this connection has previously been fine to my employer's server, it's just been the last 3 weeks or so when the problem seems to have arisen.
I realise that you're probably unable to help further on this, but I'm grateful for what you have done in getting things this far. I don't know if the TalkTalk team are able to help any further?
Thursday
Morning Darren,
We'll check back in with you in a few days to see how you're getting on.
Wednesday
Hi Keith, thanks for this update, it may have fixed things:) I'll check over the next couple of days, though as sometimes I have been able to connect through the vpn and then the problem has arisen again. If it is fixed, I'll action the 'Accept' as requested.
If it's not fixed it, I'll repost the post that was deleted (as far as I can remember what I wrote). Sorry I didn't get to this before now, I've been tied up with some other things over the last couple of days.
Best regards
Tuesday
Hi @DarrenW66
Apparently, there was a bug in Windows 10/11 that has been affecting VPNs recently (mine were unaffected). This has been fixed in the Patch Tuesday update for Windows released today. Although this is normally a security only update, Microsoft has also rolled out this fix as well. Once updated, please can you retry? I am not hoping for much, but you never know.
Tuesday
Hi DarrenW66,
Your last post has been automatically moved to spam quarantine. Could you try posting it again without the link, hopefully this will go through OK
on 13-05-2024 03:53 PM
Hi @DarrenW66
Which VPNBook SSL servers were you using, I haven't found any supporting SSL. What I did do was to analyse a connection attempt of my own that gets to about 48% using a VPNGate SSL server in Wireshark. The Forticlient contacts the server and performs some encrypted exchange. Are you sure that you don't need to use any certificates? Did this ever work to your employer's VPN server?
on 13-05-2024 03:41 PM
Hi again Keith, thank you for persevering with this.
Generally it gets to 40% before failing.
Interestingly, if I run the open vpn (vpnbook) on my machine and then connect to Fortinet, it seems to connect much better.
I don't know if that helps explain the problem here?
Thank you again,
on 13-05-2024 11:06 AM
Hi @DarrenW66
I have been trying all of the free SSL VPN servers that I can find & can't connect to any of them. When you try & connect to your work network, what percentage does the connection reach before it fails?
on 10-05-2024 02:45 PM
Hi @DarrenW66
Thanks for that, I'll give it a try & come back to you.
on 10-05-2024 02:12 PM
Thanks Keith, just sent to you....
on 10-05-2024 11:53 AM
Please can you send me a PM (to protect your Privacy) with a screenshot of how you have it configured, so as I can test this in the same way that you are using it?
on 10-05-2024 11:46 AM
Thanks, I'll have a look at it.
on 10-05-2024 11:41 AM
