on 02-11-2023 12:57 PM
Hello, I was upgraded to fibre 150 with digital voice yesterday, but my Grandstream digital voice adapter won't register my phone.
I left the digital voice adapter connected to my eero 6 all night long, but the phone indicator still doesn't light up. The other two indicators do though.
I read through the forum yesterday, so I've already tried the following...
Any combination of the above doesn't solve the problem.
Yesterday if I reconnected my phone to the older master socket then I was still able to make calls, but today it's totally dead. And if I call my landline from my mobile it goes straight to voicemail.
on 10-05-2024 06:23 AM
Hi Dave,
Great, thank you 🙂
on 09-05-2024 03:52 PM
Hi Michelle
All sorted! I got up this morning and everything is working!😊
I am very impressed with the service I received and the full fibre!
Best wishes Dave.
on 09-05-2024 06:53 AM
Hi Talman,
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
on 08-05-2024 08:22 PM
Hi I upgraded to full fibre 150 today and have the same issue! While it doesn't help solve the issue it is reassuring to know I am not the only one and I am not being dense! Hopefully it can be sorted out soon!
Best wishes Dave.
on 19-03-2024 08:53 AM
Hi Pedra1,
If you still need assistance can you please start your own thread as Gliwmaeden2 has suggested
on 18-03-2024 10:06 PM
Please start your own topic, @Pedra1.
This one is another customer's and not in the workflow any more.
You need to return to the message board for Home Phone and click on start a topic.
Staff will reply during the day.
on 18-03-2024 06:37 PM
how do I find out if a call forward has been put on my landline number.
on 18-03-2024 06:34 PM
My symptoms are exactly as yours and I have tried to reset several times without any success.
on 13-11-2023 12:14 PM
That's great, thanks for letting me know 🙂
on 13-11-2023 12:13 PM
Thank you! It works perfectly now.
You should be safe to close the fault ticket that's logged to my account too, since it seems like the troubleshooting that I did helped to resolve the issue for myself and many others too.
If I experience any further issues then I'll be back. But so far calls sound decent and my phone seems to be fully compatible 🙂
on 13-11-2023 11:43 AM
OK, I've removed the divert. Can you please test and let me know if calls are coming through OK
on 13-11-2023 11:11 AM
Done. I'm just waiting on you now Chris.
I'm sorry if I did make a mistake the first time I filled it out. I think I might of been too eager and skimmed over that last question, since when I last spoke to your network teams they asked me for the second character.
on 13-11-2023 09:16 AM
OK, no problem. I've sent you a PM to confirm some details then we'll remove it for you
13-11-2023 09:06 AM - edited 13-11-2023 09:11 AM
Yes please, since it seems like it's the only thing that's preventing me from receiving calls to that phone now.
on 13-11-2023 07:54 AM
Hi theblackcat,
Apologies for the delay. If you'd still like us to remove the divert could you let me know and I'll confirm some details with you
on 10-11-2023 06:43 PM
Yeah, it seems like they finished before 4pm today.
I'm not in a rush and I don't trust the online chat to configure VoIP settings correctly, so I'm just going to wait until Monday.
on 10-11-2023 06:25 PM
Staff will be back after the weekend, @theblackcat.
If it is urgent to disable call forwarding, phone 03451 720088 by 7pm today / 9am - 6pm Saturday, or use Chat to get it removed sooner.
10-11-2023 02:59 PM - edited 10-11-2023 05:00 PM
I connected my DVA directly to my ONT and then reset it, just to be sure it'd work. And it did! 😁
It sounds like my troubleshooting is what pointed your teams in the right direction, since the config file is being downloaded and applied now.
Could you please disable call forwarding and make sure that any VoIP related settings are enabled so that calls can get through? Thank you!
on 10-11-2023 01:53 PM
OK, no problem
10-11-2023 01:33 PM - edited 10-11-2023 01:48 PM
Thanks Michelle! I'll report back in an hour if it's worked.
If it does work then I'll need someone to disable call forwarding, since that was temporarily enabled by your network team on Monday so that calls to my landline are forwarded to a household members mobile. And that also stopped the digital voice app from working correctly, since it doesn't receive calls or 1471 updates.
