Eero 6 updated overnight and now issues with 2.4 ghz devices
phils5887
Message 35 of 35
My eero 6 updated last night and all my 2.4 hz devices have stopped working.
I managed after lots of messing to get some things back on but the 2.4 still keeps dropping. Ive tried turning ipv6 on and off.  Legacy mode and pausing 5hz. I think its now a router issue?
Ive tried multiple resets both hard and via the app.
Before the update everything seemed ok but some of the 2.4hz devices did disconnect on and off on a dsily basis.
My ring camera won't connect at all even when pausing the 5hz.
Do you have any idea?
Thank you
Philip
34 REPLIES 34
Message 21 of 35
HI Michelle
Ive refitted the eero. A lot of the devices came back online but i had to manually reset and add the reolink camera and another camera cam720. When i plug in the old one i never have to so this. They seem to be up again. But this happened yesterday and they then dropped off?
I cant understand how the eero is so bad with 2.4 ghz devices.
Kind regards
Philip
Message 22 of 35
Hi Phil,
I've received an update to advise that eero have manually adjusted the channel to avoid interference. Would you mind retesting please and let us know if there is any improvement?
Message 23 of 35
Hi Phil,
Thanks for confirming and I will let you know as soon as the team come back to me.
Message 24 of 35
 Hi Michelle
Im not too sure if it updated again, i thought i was on 7.3.0 software yesterday.  The devices dropped off at different times. The ring camera went down just after midnight and i think the updates occur around 3am?
I have no drama when using an old router although very poor signal. The eero meshes through my amazon alexas giving great speed/coverage on the 5ghz band.
There is definitely something up with the eero since the recent updates.
Looking forward to hearing from you
Kind regards Phil
Philip
Message 25 of 35
Hi Phil,
Thanks for your PM and I'm sorry to hear this. I've passed this back to our Devices Team again. Can I just confirm, has the firmware/software version changed on the eero again?
Message 26 of 35
Hi Phil,
Thank you for the update and I've let our Devices Manager know now.
Michelle 🙂
Message 27 of 35
Hi Michelle
Thanks for the message.
The eero has updated again last night to another software version.
Since the update it is now working on 2.4 ghz.
The device is currently plugged in but it wasnt for a period due to it not working.
Thank you for all your help and assistance much appreciated
Philip
Message 28 of 35
Hi Phil,
The team have asked us to confirm if your eero is currently online at the moment please?
phils5887
Message 29 of 35
That's brilliant thank you very much 😊
Philip
Message 30 of 35
Hi Phil,
Thank you 🙂 I've raised this over to our Devices Manager for investigation now and will post back as soon as I have an update.
phils5887
Message 31 of 35
Good morning Michelle
Thanks for the reply.
I have updated the account details.
I hope this helps.
Phil
Philip
Message 32 of 35
  • Name
  • Account Number
  • Alternative contact number
phils5887
Message 33 of 35
Hi Keith
Thank you.
That will be much appreciated.
Philip
Message 34 of 35
TalkTalk will have to investigate this, there is nothing I can do as a customer & it has only happened since this update. I will escalate this to them now, for when they return tomorrow.
