on 10-04-2024 01:11 PM
Hi there! Can anyone tell me why the devices listed in MY DEVICES are duplicated over and over.
According to the list I have 20 devices connected to my new sagecom router all working correctly.!!!!!
In fact I only have 11 devices, 2 of which are not on the list.
The other devices are duplicated over and over.
One device appears 4 times and others 2 times. No way for me to amend it and TalkTalk no help.
Any ideas?????
Monday
Thanks for the update. My colleague here also raised the duplicate devices showing in My Connection to the team.
Monday
Hi Michelle,
I have spoken to the Escalation Team
The wired PC appears to be working with no problems.
He assures me there is currently no fault with the line despite what MY CONNECTION says.
On his system he can currently see 4 devices which is correct.
He does not know why MY CONNECTION is listing 21 devices including all inactive devices but he will pass the problem over to MY ACCOUNTS team to investigate the corrupted communications.
He will close the current fault down but the system will just raise another one unless something is done.
The only solution would be a faster package but until FTTP is available nothing can be done.
My broadband cannot support the few wifi devices I have. Our 2 mobile phones struggle to connect to the internet even with all other devices turned off and we often have to switch to mobile data.
I will reinstate my other devices to share what line speed is available.
The information in MY CONNECTION is corrupted and of no use to me
Hopefully the service to my PC will hold up!
Soloman13
Monday
Hi again,
Can I just check, have you now been contacted by our team?
Monday
Good morning,
I'll chase the team for an update on this now.
Monday
Good Morning,
No contact from the Escalation Team.
My wired connection to the PC is looking stable with no problems over the weekend but still MY CONNECTION still shows further work required
However, As previously posted I disconnected all devices just leaving the booster, extender and two mobile phones active.
My DEVICES has listed all the switched off devices as Active and working as expected over the weekend.
This morning MY DEVICES shows 20 devices working as expected with multiple duplications.
What on earth is going on??????????
Soloman13
Monday
How has your connection been over the weekend? Has our Faults Escalation Team been in contact?
Friday
Hi Michelle,
For your information, MY CONNECTION tells me that 'our diagnostic tool has picked up on a potential issue but to help us understand whats going on you'll need to run a more in depth line test'
I have done this several times but no conclusion reached
My Echo is still listed as consuming my upload speed despite being unplugged for more than 24 hours!!
I have removed all WiFi devices except for the Booster, The Extender and both Iphones. The PC is still hard wired to router.
We will see if anything changes over the next couple of days.
Soloman13
on 09-05-2024 01:27 PM
Please remember that it is MY CONNECTION that is raising these faults and opening cases.
Soloman13
on 09-05-2024 01:22 PM
Thanks Michelle.
I have a current line speed of 11mbps which should be more than enough to cope with the type of devices I have and their limited use?
Soloman13
on 09-05-2024 01:12 PM
I've escalated this over to our Faults Escalation Team now and have asked them to take a look. We'll post back here as soon as we receive an update. It's possible that the team may also try and contact you directly.
on 09-05-2024 12:56 PM
Please read previous posts .It does not help asking the same questions over and over.
Once again, Fibre To The Premises is not available!!!!!!! Openreach Engineer confirmed last week!!!!!
There is 1/2 mile of copper wire from the cab to my premises which is why FTTP is not available and why line speed drops so much by the time it reaches me.
Soloman13
on 09-05-2024 12:40 PM
Hi Soloman13
I would suggest faster speeds to support more devices. Is FTTP available in your area?
It would be worth speaking our Loyalty Team to see what services/packages they can offer you.
on 09-05-2024 12:23 PM
My wired PC is on all the time
The Echo And Echo Show are on all the time
The Iphones are on all the time
My TV box is off most of the time as I cannot stream any programmes over the internet
My Sonos Beam is off most of the time and only connects for updates.
Are you saying my connection cannot handle even these few devices ? with the help of booster/Extender/Powerline units?
Why is MY CONNECTION keep throwing up faults?
I don't have a usable broadband connection which is why I rely on my wired pc so much. But even this can have issues as this post can attest to.
Can anything be done to improve matters?????
Soloman13
on 09-05-2024 12:01 PM
Hi Soloman13
I'm guessing this is linked to how many devices there are and which ones are connected and using the connection (based on your current sync speed) at the time you experience the issue.
The connection appears to be stable with no drops in connection.
on 09-05-2024 10:37 AM
Good morning, I have left the Echo disconnected, Nothing has changed as far as I can see.
Has the congestion eased.?
Has their been any further reconnections since the Engineers visit?
Still getting a fault page in MY CONNECTION.
Of my 11 devices :-4 are devices to improve wifi signal in the home
1 is hard wired into the router
1 is currently turned off
2 struggle at times to connect to wifi
3 regularly are reported as consuming my upload speed
FTTP is not available. We have at least 1/2mile copper cable between where the cab is and my premises.
Soloman13
on 09-05-2024 06:41 AM
Thank you for the update. Have you noticed any change so far? Is FTTP currently available for you?
on 08-05-2024 02:38 PM
No problem I will unplug the Echo for now.
My devices are:-
Desktop PC
Sagecom Booster
Talktalk Extender Kit
Iphone 14
Iphone 7
Amazon Echo
Amazon Echo Show
Sonos Beam
TV Box
TV Powerline B1
TV PowerlineB2
That is 11 devices but these are often duplicated reaching 24 at one point See previous posts
Only the Extender is duplicated at present
Soloman 13
on 08-05-2024 02:06 PM
I've also checked your wireless connection stats and it also shows upstream congestion. Would it be possible to test with the Amazon Echo removed for a short period just to see if there is any improvement so we can confirm if it's definitely related to this one device? How many wireless devices do you currently have connected please?
on 08-05-2024 01:31 PM
The line tests are ALWAYS clear.
They were when The Openreach engineer visited and yet there was a resistance fault in the Cab which your tests did not pick up.
The Engineer did also refer to another potential fault on a pole see previous post.
WiFi is poor at the best of times despite having a talktalk Sagecom booster and an extender kit.
Currently My Devices tells me that my Amazon Echo is consuming my upload speed and my Iphone 14 struggles to connect to WiFi.
Soloman13
on 08-05-2024 01:17 PM
I'm not sure what issue it detected as the line tests are clear. I can see that fault ticket that has been auto logged and it has requested further diagnostics to be completed. Are you experiencing any issues with the wireless specifically?
