on 07-05-2024 01:09 PM
Hi all,
Hoping somebody can help.
Over the last few weeks I have been having issues with devices on the network not getting an internet connection. Devices - mostly been using my iPhone to troubleshoot - will remain connected to the WiFi, however they will not have a connection. Simply toggling the WiFi on and off on the device quickly fixes the issue. I have tried resetting the router, and this only works temporarily.
I have tried manually setting a channel for the 2.4 and 5ghz networks, and this can fix the drops out for a day or two - however at random the router selects a different channel and the issues persist again.
I have seen there are a lot of posts on this forum about WiFi optimisation on the router and this being the issue. Is anybody out there able to confirm that this is the issue and if it is something talktalk acknowledge with the router?
If this is the case - can somebody from talk talk disable this setting on my router? As I say - I can pick my own channel and everything seems to work fine - but as there is no user setting to turn WiFi optimisation off the router just has a mind of its own.
I will stress that I do not want to factory reset the the router - despite me thinking this won’t make a difference, I have had previous issues with getting my Xbox to stay on an open NAT, and after much work I have finally got this sorted.
Cheers guys!
Dan
Wednesday
We can always check out your WiFi reception generally.
Wednesday
Just another thought, could you confirm the makes and models of the apple devices that you're using please and also what version of software is on them too?
Wednesday
Thanks Dan and please let us know how you get on.
Wednesday
Hi All,
Thank you for your continued help. @KeithFrench Do you have anything you can point to that would indicate this is an IOS issue and not an issue with the talk talk router? Reason I ask is I haven’t had this issue with my phone on my work WiFi which I use around 8 hours every day. If it is an IOS issue however, I guess that would explain why disabling WiFi optimisation fixed the connection issue for my other devices but not my iPhone.
@Michelle-TalkTalk I will try a 30 minute power down today and see how it goes. I will report back!
Many thanks,
Dan
Wednesday
@DanMay94 Just noticed a similar topic that my colleague has been responding to this morning where a 30 minute router power down seems to have resolved the issue. Have you recently tried this too?
Wednesday
Thanks @KeithFrench
@DanMay94 Have you noticed if this started happening after a software/IOS updates on your apple devices? Do your apple devices currently have the latest updates?
Wednesday
Yes, I have seen this before, it seems to be an Apple issue where the iPhone or whatever shuts down the WiFi connection to conserve battery usage, but is unable to recover correctly from this for some reason.
Wednesday
Hi Dan,
As far as I'm aware this is not a known issue specifically with apple devices. @KeithFrench have you come across this before?
Have we ever sent you a replacement router for testing?
Wednesday
Hi Michelle,
It happens on both 2.4 and 5… I can’t seem to make rhyme or reason of it! As I say, there are several posts on this forum complaining of the same thing - so I’m not alone! Before my WiFi optimisation was disabled it was happening much more regularly however, and my TV which used to lose connection is now fine - it just seems to be mine and my partners iPhones that seem to disconnect, although as I say now less frequently than before…
Dan
Wednesday
Hi Dan,
No not specifically. Are your apple devices connected to the 2ghz or 5ghz channel when this happens please?
Wednesday
Hi Debbie,
Thanks for this - although end of the year is still a fair way off! Does talk talk acknowledge that this disconnection issue I’m having, seemingly only with Apple devices for now, is indeed an issue with the router itself. If not, is there anything else your technical team can suggest me trying?
Dan
Wednesday
Hi Dan
Our Devices Team have advised that the new firmware rollout is expected at the end of the year.
Wednesday
Hi Dan
There is a new firmware version for the Sagemcom wifi hub coming soon. Let me check with our Devices Team to see if I can get a date for when this will be rolled out.
Wednesday
Hi Michelle,
Things are generally improved with most devices like my TV now staying connected, however I still am getting the odd disconnection - but it only seems to happen on iPhones. In the last 2 weeks I would say I have had the ‘no internet connection’ error on my iPhone 3-4 times, which again, is quickly remedied by toggling the WiFi on and off again on the phone however it is frustrating. I have had a look on the forums and I can see others seem to also have this issue, especially with Apple devices it seems? Is this something you guys are aware of? Is there a firmware update for the router as of yet?
Many thanks,
Dan
on 17-05-2024 07:07 AM
Morning Dan,
Just checking back in to see how you're getting on?
on 13-05-2024 06:57 AM
Hi Dan
I'm so glad to hear this 🙂
on 10-05-2024 03:30 PM
Hi Debbie,
Yes James has been in touch and has been very helpful and understanding, as have you. I think we’re on the way to a solution. Thank you very much for your help, and I will be back in touch if I have any further issues in the future.
Thanks again!
Dan
on 10-05-2024 07:41 AM
on 08-05-2024 09:47 AM
on 08-05-2024 08:47 AM
Hi Dan
I thought this would be the case. Let me speak to the team again now.
