WiFi drops out
Message 30 of 30
In the past couple of months WiFi periodically drops out. There is no pattern as such but it is very annoying. The tho ha that keep dropping out are my ring doorbell and all SimpliSafe devices. The only way I can get it to reconnect is to reset the router. I have reported the fault to talk talk and they keep telling me everything is ok but it isn’t. What do I need to do to sort this out as I can’t carry on as I am.
Maurice Taylor
29 REPLIES 29
Message 1 of 30
Glad the new router has helped. Keep an eye on things, and any issues, just report back here.
Message 2 of 30
Hi Debbie,
fingers crossed everything it seems to be ok. The alarm has dropped out twice but unlike the old router this one seems to kick the connection back on within seconds. Really pleased 😁
Maurice Taylor
Message 3 of 30
Message 4 of 30
Hi 120265Mauricetaylor
That's great news 🙂
I will check in again with you on Monday to see how the connection has been with the new router.
Message 5 of 30
Hi Debbie
The router has arrived and I have plugged it in and touch wood all seems to be going fine so far.
If it all works for a whole week I will let you know
thanks for your help so far
Maurice Taylor
Message 6 of 30
Message 7 of 30
Message 8 of 30
Thanks Keith
i will let you know how I get on one way or another.
Maurice Taylor
Message 9 of 30
Maurice Taylor
Message 10 of 30
HI 120265Mauricetaylor
Thanks for your reply 🙂
Thanks @KeithFrench
Message 11 of 30
HI @120265Mauricetaylor
Once you get the new router, if you should still get the same problem, let me know & I will be happy to help.
Message 12 of 30
Hi Debbie,
I am happy to try anything so yes please
Maurice Taylor
Message 13 of 30
Would you like me to send a replacement router for testing?
Message 14 of 30
Hi Debbie
I have had this router as long as I can remember. Many many years
Maurice Taylor
Message 16 of 30
Hi @Debbie-TalkTalk
I'll hang fire until you decide what you want to do with the customer's router.
Message 17 of 30
Can I just check, when did we last send you a replacement router?
Message 18 of 30
Hi keith
thanks For your offer of help. I am not very technical so please forgive me if I don’t give you the information you need. As far as I know I have a talk talk WiFi hub.
Maurice Taylor
Message 20 of 30
Hi @Debbie-TalkTalk
I am waiting to see if this customer still requires my help.
