on 04-05-2024 01:25 PM
I'm on Fibre 65 with max Speed vrying between 40-46 Mbs.
I have had a new talk talk router sent a month or so back (thank you). It seems i get intermittant disconnection from my devices and the router. Also extremely slow speeds sometimes of less than 1Mbps. When i do speed tests etc it can sometimes pick up later. It never used to be like this before.
I am unsure if the router is disconnecting me or if the Talktalk connection is at fault. When i do a connect test it says there are intermittant drops in my connection and to chat to talktalk. However the chat box opens but no one seems to answer!
I have changed WIFI channels. Made sure only a select few devices are connected. It seems this disconnect affects all devices and i think at the same time. This makes me think is the router faulty or the connection to talktalk?
Any advice?
an hour ago
Hi ShahAA
I'm glad to hear that the connection is performing better with the new router.
Apologies, we are unable to switch off WIFI optimisation.
yesterday
Wifi optimisation can't currently be switched off even by support staff, @ShahAA.
yesterday
My new router works better. Not 100% perfect but less cutouts.
I will send the old router back to the Talktalk Returns, EN110AQ address.
One Favour, is there ANYWAY i can diable wifi optimisation. I think this may be somethingthat needs to be done at your end, i wonder if i do that then i will get less dropouts. I am now thinking the dropouts are due to wifi channel changes. I read somewhere you guys need to DISABLE wifi optimisation.
Thursday
Please do return the other router as soon as you are able.
Thursday
Yes, i have the bags and once i know things are improved in a weeks time i shall send the old router back. Thanks once again.
Thursday
Hi Shah
Thanks for letting us know.
Did you receive a pre paid returns bag in the box the new router arrived in?
Thursday
Hi Debbie, received it on Tuesday. Just set it up today.
I will see how it goes. It seems i can access the itnernet and all is working, but hoping i dont get dropped connections and bootouts (Seems the router kicks everyone off) like the last one. If its all ok, I will let you know, but will need about a week to test stability. If its all fine, let me know how to send the old router. thanks.
Shah
Monday
Hi ShahAA
on 10-05-2024 10:37 AM
Hi ShahAA
No problem 🙂
I will check in again with you next week to see how the connection is with the new router.
on 10-05-2024 10:34 AM
Thank you.
on 10-05-2024 10:05 AM
Hi ShahAA
In regards to the router channels, I just wanted to check if the connection was stable until the channel changed again?
on 10-05-2024 09:55 AM
That would be great.
Can i ask, you asked me about the channels resetting. what significance does that play..?
on 10-05-2024 07:44 AM
Hi ShahAA
Would you like me to send a new router for testing so we can rule this out?
on 09-05-2024 05:36 PM
Hi Debbie,
Yes, it seems the connection defaults to 6 on 2.4g and defaults on the on 5g as well. BUT i dont think this is the reason this is happening because even when defaulted it still kicks me off and my device has to reconnect. If it was only one device i would understand but it seems its my home PC and other phones in the house as well.
on 08-05-2024 06:54 AM
Hi ShahAA
Thanks for the additional information.
When the connection next drops, could you check to see if the wifi channel has changed back?
on 07-05-2024 09:54 PM
Hi Debbie,
So i have rebooted the router. This can occur intermittantly through the day, a sudden drop in my device connecting to the router. Sometimes my deveice will then find hte router nad reconnect automatically. Its as if the router deced to kick us all off the network!
The wifi channels stay (i think)
its owrking perfectly fine now but intermitantly will kick us all out.
on 07-05-2024 01:57 PM
Hi ShahAA
Can I just check, when this issue happens do you reboot the router? Or have you tried rebooting the router and retesting again?
on 07-05-2024 01:49 PM
Router details:
SAGEMCOM
Devicer version FAST 5364 3.T8
Channels saty when changed.
I notice that when it disconnects, all my devices are disconeected. This leas me to beleive there is a issue with the router and not the internet, as if it was the internet then it would say internet down and not disconnect from the router.
The router is located in the same area as my previous router. When i bought a temporary rotuer from the shops, i did not have this disconnection issues. We dont have multiple devices connected in one go either.
on 07-05-2024 08:32 AM
Hi ShahAA
I've completed a line test and this is clear - No faults detected.
The connection also appears to be stable, no drops are showing.
Which router do you have? (make and model) When you change the channels, do they stay on your chosen channel or change back again?
on 06-05-2024 05:01 PM
It is best if you start your own topic so that the support team can look at your issue individually.
