on 29-02-2024 11:15 AM
Just renewed my a/c in Dec'23 and 14258 stopped working. Was told to use call block, but this doesn't work when you're sent a pass code by a BOT. The phone just goes dead!
Was then told to use last call barring......but 14258 says "sorry the service requested is not available". Please......how do I get the 14258 service back.....more so because call block is not suitable if your contacting your Banks to get a login from a BOT.......HELP
on 26-04-2024 07:53 AM
Hi DuncRha
That's great, thanks for letting us know.
on 26-04-2024 07:26 AM
An update, call blocking still working well, have not received any unsolicited calls for weeks. Thanks again for the help Chris.
on 01-03-2024 02:12 PM
That's great, if you do experience any further problems just let us know
on 01-03-2024 01:41 PM
All seems to be back on and working, thanks Chris.
Now to see what happens over the next few weeks, will it all still stay be the same?
on 01-03-2024 08:11 AM
Hi DuncRha,
Just to confirm, is it still not working?
on 29-02-2024 02:52 PM
Debbie, Just for information
"My Telephone Setting" is within "Profile & Settings" not "Network & Connection", at least on my system.
on 29-02-2024 02:34 PM
Switched it off last call barring then updated. logout then login "last call barring is still on. What now?
on 29-02-2024 02:05 PM
Hi DuncRha
Did you recently activate/add this in My Account?
If you did then please can you try removing this in My Account and then re adding again in a couple of hours?
on 29-02-2024 01:59 PM
I have "last call barring" on but 14258 says that it's not on.
on 29-02-2024 12:15 PM
Hi Royal-Scot,
I'm sorry to hear this. Please can you create your own topic and we'd be happy to look into this further for you.
on 29-02-2024 12:10 PM
I have the same problem.
on 29-02-2024 11:37 AM
Hi DuncRha
Can I just check, have you had a look at this help page Using Selective call rejection (Last Caller Barrin... - TalkTalk Help & Support
