on 27-04-2024 09:03 AM
When loading the Guide, it’s very slow and when running through it.
recently has been difficult to delete recordings too.
Tuesday
The issue affecting the guide has been resolved. This was caused by an external factor that has now been resolved.
Saturday
Hi, @Danni0176
Karl is collecting data from customers under the following thread if you could add your experience there please.
He's not back until Tuesday but is working with YouView who are actively seeking a solution.
Thank you
https://community.talktalk.co.uk/t5/TV/YouView-TV-Guide-not-working-or-slow/m-p/3038974
Saturday
I have a box DN372T which I havec tried all above and still not working what else can I do as so frustrating
on 02-05-2024 11:50 AM
Hi All,
If you can please follow these troubleshooting steps from YouView, and let me know . and please drop me a PM with the serial number and model of your box, It will either be DN360T, DN370T or DN372T :
Some things we’d like to try before they do a factory reset:
on 02-05-2024 07:57 AM
Glad to hear that the performance has improved.
For any others affected, pleasr remove the aerial from the box, retune the channels, connect the aerial back to the box and retune again, then test the performance of the guide.
on 01-05-2024 06:26 PM
All seems to be working well tonight ,fingers crossed .
on 01-05-2024 12:51 PM
Hi All,
YouView have advised that if this issue is still affecting your box, try a Retune of the freeview channels and then see if that helps.
on 01-05-2024 11:47 AM
YouView have implemented a change so pleae retest the guide to see if all is now ok.
on 01-05-2024 08:03 AM
I'm glad to hear the Guide has started working correctly for you.
Our Teams are still investigating with YouView and working to deploy a solution soon.
on 30-04-2024 09:59 PM
I have found that, after starting up the box and having to reload youview (and still having unresponsive or very slow reponse on guide), the guide/channel selection and other features of guide seem to speed up and are back to normal (it took about 3 hours tonight to get to this situation.)
on 30-04-2024 06:07 AM
We do apologise for the inconvenience this issue has caused, and YouView are investigating as a priority.
on 29-04-2024 08:43 PM
Youview have got a problem with the boxes . They say they are trying to fix it. There appears to be nothing we who are trying to watch can do . It seems to get worse on a evening. Resetting doesn't make any difference . It's very frustrating !!!
on 29-04-2024 08:08 PM
I have done ever reset possible and still have the issue on two boxes..
on 29-04-2024 02:32 PM
OK, thanks for confirming.
on 29-04-2024 02:29 PM
Tried the reset didn't make it any better. I now have to reload every time I switch youview on. The guide is working at the moment. !!!
on 29-04-2024 01:55 PM
Can anyone in this thread confirm if they have performed the maintenance reset and if it helped.
on 29-04-2024 08:10 AM
An incident has been raised by YouView. There is an issue with the TV Guide not loading correctly. YouView are investigating currently.
You can try a Youview Maintenance Reset to see if this helps.
on 28-04-2024 07:17 PM
Talktalk TV guide unresponsive and unable to use it all possible scenario’s done and still useless. It must be Talktalk’s problem but they won’t admit it. 🤬
on 27-04-2024 10:50 AM
Talktalk are having problems with the TV boxes not working properly. There is no point in new batteries or resetting as the problem is talktalk's not yours. They are just not telling people there is a problem. !!!
on 27-04-2024 10:20 AM
Oh and I assume you have tried new batteries in the remote already.
