on 20-04-2024 05:27 PM
Hello
All
I wanted to ask has anyone got Iplayer UHD working on the TalkTalk TV hub
Are TalkTalk aware of this ?
Is there any fix for this
on 21-04-2024 01:59 PM
No it's not irrelevant.
As I have said my 2 TVs provide different results. One with UHD, the other without. This I understood was the correct behaviour as only is 4k compliant.
Doing a Google search this morning shows that certain makes of TV and different models within the make also have issues.
If there is a handshake / CEC issue between box and the TV that is not transmitting your TVs spec to the box, so that UHD programmes are not shown, then it is totally relevant.
on 21-04-2024 01:48 PM
Providing My TV details is irrelevant
The TV Hub needs a software update to fix the Iplayer UHD bug
This needs to be passed to TalkTalk and needs to be passed To the BBC for a fix
Otherwise I am going to stop using the TV hub
on 21-04-2024 01:46 PM
Yes the box outputs 4k on android level
Youtube 4k works but Iplayer UHD does not
BBC are going to take more notice If TalkTalk speak to them rather than customers
on 21-04-2024 01:45 PM
If one device works with Iplayer UHD and another device which is meant to be better than the other it should still play Iplayer UHD
Otherwise why would customers upgrade the TV boxes when one thing stops working
on 21-04-2024 01:32 PM
@Ineedhelpfrom as requested can you please also supply the make and model number of your TV.
Thank you.
on 21-04-2024 01:09 PM
And to reiterate, UHD does work in the app, just, it appears not on some TVs.
And as I and @ferguson have said, it lies with the app owner, the box is just the delivery mechanism for providing the service.
The are many versions of the same apps out there.
For example some ITVX apps only provide catch-up and not access to live channels so what works on one device won't work on another.
It's why support for the old YouView box apps is no longer there. The software cannot be run on the hardware the boxes use.
on 21-04-2024 12:50 PM
I don't understand why you insist if it works on X then it should work on Y, that isn't necessarily the case.
TalkTalk will I am sure take account of your concerns, but in reality responsibility for any capability issues with the app rest solely with the owner, which in this case is of course the BBC.
on 21-04-2024 12:01 PM
I think TalkTalk should log this a fault as well.
I am sure others are experiencing the same issue
If it works with the netgem box then should work the TV hub box as well
Fixing this will benefit lots of customers
It can be done in a software update
on 21-04-2024 08:15 AM
I've had a look through the TV board and can only see one other report (I may have missed some) and that was a person using a computer monitor not a TV.
I did a Google search too, and can see other boards reporting incompatibility with iPlayer and certain TV makes.
The consensus seems to be that following updates the iPlayer does not work with UHD.
As said reporting to the BBC is probably the best solution at the moment.
I will leave it now and let support staff comment further next week.
on 20-04-2024 07:34 PM
Whilst the iPlayer may look the same, the software does vary between appliances. The box is the delivery method for the app. Maybe there is an incompatibility with the app and the box, in which case you have done the correct thing reporting it to the BBC.
For info it may be of interest to detail your TV make and model number.
If my testing was coincidental and there is an issue between box and TV, then for info my TV that does not show UHD content is a Samsung.
As said wait for support staff next week. I've run out of ideas except
on 20-04-2024 07:01 PM
I am using the supplied HDMI cable
TV UHD is on automatically
I have sent a support ticket to BBC Iplayer as well
The iplayer app on the Netgem Box would be the same version on the TV Hub
So If it works on the Netgem box it should work on the TV Hub as well
The TV Hub box is doing all the communicating, The Tv is just a screen
I have seen others having issues with Iplayer UHD with the TV hub
on 20-04-2024 06:53 PM
Have you got to turn on UHD on your HDMI port? Some TVs require the resolution to be changed.
Are you using a 4k rated HDMI cable?
Search your TV model number in Google to see if you need to do anything to get UHD compatible devices to work properly.
Failing that wait for support staff next week to offer further advice.
on 20-04-2024 06:42 PM
My TV Is compatible
I have seen others that are having the same issues as me on the forum
on 20-04-2024 06:38 PM
The TV Hub as explained will only show content your TV can play. There is some software in there, either at box level or App level that identifies your TVs capabilities.
It is not a fault. Support staff switched a box recently for someone and the results were the same.
I was asked to test the box on my TVs and the results confirmed this.
The Netgem box isn't so cleaver and shows all content.
on 20-04-2024 06:28 PM
I borrowed a Netgen box and UHD works on My TV with that box but does not with TV Hub
I know there should be UHD showing on iplayer and it does but only when I used the Netgen box
on 20-04-2024 05:39 PM
UHD programmes are only shown in the menu if your TV is a 4k one.
I have 2 TVs and UHD programmes show on this, but don't when I swap the box to my HD ready TV
You also need to use a suitable HDMI cable that carries 4k signals. The supplied cable should do so, but some have used their old one that was in place which was not a 4k capable one.
The TV also needs to tell the box it's 4k. Check your TV to see if you need to "install" equipment. I have to on my LG.
Hope that answers your question.
