Intermittent WiFi Connection to Apple Devices
Gordon_Arthur
Message 16 of 16
Hello, I'm on a fibre package that has been just fine for ages but latterly, perhaps in the last week or so, we have had problems where the iPhones or iPads will not link to the WiFi. I have two Windows laptops which are doing just fine. I get 40Mbps on one machine and 70Mbps on my other, it seems to be just the Apple devices. I've tried the Chat function but I can't get past the BOT to get anything sensible. I have switched off the router overnight and that had no effect. Any suggestions please?
15 REPLIES 15
Message 1 of 16
I'm glad to hear this 🙂
Michelle 🙂
Message 2 of 16
Thanks for reaching out again but I think we are all okay after the helpful input from Keith. I was fairly sure that I had already expressed my thanks and closed the issue but there may well be two email trails. Anyway, all good to close down, thank you.
Message 3 of 16
Message 4 of 16
Message 5 of 16
Hi @Michelle-TalkTalk
After doing more diagnostics via PMs. Since making some channel changes that I recommended, plus turning off an old TP-Link extender, things are now much better.
Message 6 of 16
Ok, thanks for the update 🙂
Gordon_Arthur
Message 7 of 16
Additional profile information added. Keith is generously providing me with some guidance which I am following gradually.
Message 8 of 16
Message 9 of 16
I am currently doing some WiFi diagnostics via PMs. I will update this as soon as I know more.
Message 10 of 16
Hi Gordon,
  • Name
  • Telephone number
  • Alternative contact number
Message 11 of 16
Hi @Gordon_Arthur
I will ask TalkTalk to disable WiFi optimisation on your behalf then.
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
Gordon_Arthur
Message 12 of 16
Hi Keith, I have no idea about the optimisation setting, I can't see that in the router dashboard at the moment so, if that can be updated by a TalkTalk team member, then please go ahead.
There are two bands, the bulk are on the 2.4 GHz channel. My work laptop is connected to Band 2 (5GHz), as is my (old) iPad. There is another device also, which will, no doubt be one of my wife's devices (iPad Pro) but she is not presently at home so I cannot check the name or IP.
Message 13 of 16
Yes, it is the Sagemcom FAST5364. Do you know which WiFi bands the working devices are on? One way is to logon to the router (192.168.1.1), then use a username of admin and the password quoted on the same label as the router model (called the router password). That is unless you have changed it to something else. Once into the router, go into the Advanced settings and you will be presented with a device listing showing what is connected to which WiFi band.
In the meantime, have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
Gordon_Arthur
Message 14 of 16
Thanks for your comment Keith. There is nothing in the way of obvious identification of the router. If I slide the password panel out I can see a manufacturer's label that says it's made by Sagem and is simply called a TalkTalk Wi-Fi Hub. Device Ver.: FAST 5364-3. T8
Does that give any clues?
Message 15 of 16
A lot may depend on which WiFi band the Apple devices are trying to use & which band the other working devices are connected to.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
