on 20-04-2024 05:27 PM
Hello
All
I wanted to ask has anyone got Iplayer UHD working on the TalkTalk TV hub
Are TalkTalk aware of this ?
Is there any fix for this
Tuesday
I'll chase this up, there could be a delay with the Bank Holiday Weekend etc.
Tuesday
When will it arrive, please
Not received any email notification
Tuesday
this is a box swap so you will not be charged for it. It should come with a returns bag for the other box when it arrives.
Tuesday
No
Nothing has arrived
No email nothing
Please confirm this a free box and i will not be charged for it
Tuesday
Has the replacement TV Box arrived ?
on 01-05-2024 12:04 PM
Thanks for the update
on 01-05-2024 11:51 AM
I will relay this back to the devices Team. They have also asked the box is swapped out just to rule out an individual fault with that box, so one is on the way.
on 01-05-2024 10:50 AM
Have the TalkTalk team contacted the BBC Iplayer team because the BBC Iplayer team are still saying this box is not certified and does not work with Iplayer UHD
This is a problem with the TalkTalk TV Hub and not with compatibility issues with My TV
As mentioned before it does not make sense that Youtube 4K and UHD works on the TalkTalk TV Hub as well as the box outputs 4K / UHD on the android level but then does not work on Iplayer UHD
The Netgem box works fine on Iplayer UHD so why this got broken when the TalkTalk TV Hub got released is bizarre
Please send this to the TalkTalk devices team
I am happy to provide any details about the box settings but you do not need My TV and model number
Fixing this will be helping lots of customers on a large scale
on 01-05-2024 08:15 AM
Our devices Team are asking for the Make / Model of the TV or device you are connecting the box to, so they can further investigate. You do not have to post this info publicly, but you can drop me a PM so this info is private.
on 29-04-2024 08:15 AM
I've passed your comments to our Devices Team.
on 24-04-2024 09:03 PM
I got another email back from The BBC Iplayer team and they are saying the TV Hub is not support to play UHD content
Please pass this onto the TalkTalk devices team and ask them to clarify with the BBC Iplayer team
on 23-04-2024 03:49 PM
I did test the TV Hub on another TV and iplayer UHD did not work neither so this means something is not right on the TV Hub
on 23-04-2024 03:44 PM
According to the bbc iplayer team they are not certified
please pass this to the devices team
on 23-04-2024 03:40 PM
Which is also why both I and @ferguson asked you for your TV details very early on.
And as I mentioned UHD is playable via my LG 4k TV but not my HD Samsung TV.
on 23-04-2024 03:13 PM
The Hubs are certified and do play UHD content. I have one here that plays UHD content from Iplayer on my LG TV.
I've dealt with another customer in the past that had a couple of TV's.
IPlayer would play UHD content on one model, but not the other, so clearly an issue between the TV and the box.
This is one of the reasons I ask for the TV model for testing. I also advise customers to test their box on another TV to verify this.
on 23-04-2024 02:36 PM
I got a reply from The BBC Iplayer team and they are saying the TV Hub needs to be certified in order for the Iplayer to play UHD content
on 23-04-2024 11:45 AM
Thanks @Karl-TalkTalk
on 23-04-2024 08:21 AM
I've passed this into to our devices Team.
on 22-04-2024 02:55 PM
Here is the requested information
youview, version
Version 2024-01-10-0a212a0d12-tta
on 22-04-2024 02:26 PM
They have asked if you can confirm the CL (custom launcher) version for youview.
Go to: Settings / Apps / See all apps / Show system apps / System apps > Scroll to bottom to click on YouView (alphabetically)
How to check the CL version within app?
Highlight the text box and click ok; then version displays on the Right-Hand Side (RHS)
