WiFi connected but no internet
HBurbs
Visitor
Message 19 of 19
Hi, I’ve got fibre 65 and multiple times a day getting the ‘connected - no internet’ message. Only solution is to restart the router. Speeds are also slow. Could a new router be needed?
18 REPLIES 18
Message 1 of 19
Morning HBurbs
Could you try the test socket first please?
If the connection continues to drop with the new router, cables, filter at the test socket then the next step will be an Openreach engineer visit.
Message 2 of 19
When the new router arrives today, do you want us to plug it in via the test socket or the normal socket?
Message 3 of 19
Hi HBurbs
Message 4 of 19
Yes please, then at least we can check if it’s a router issue.
Message 5 of 19
Hi HBurbs
Apologies for this.
Would you like me to send a replacement router for testing so we can rule this out?
Message 6 of 19
The router needed a reboot yesterday evening as we had the same ‘connected: no internet’ message on our devices. WiFi is flaky and slow today.
Message 7 of 19
Hi HBurbs
How's the connection been?
I've checked the connection stats and no issues have been detected.
Message 8 of 19
Hi HBurbs
Thank you. We will also check the connection stats tomorrow.
Message 9 of 19
Yep that’s fine, we’ll leave in the test socket and check back tomorrow
Message 10 of 19
HI HBurbs
Thank you 🙂
Would it be possible to leave the router in this set up for 24hrs to see how the connection compares?
We can check in again with you tomorrow to see how the connection has been.
Message 11 of 19
Ok, it’s connected at the test socket now
Message 12 of 19
Hi HBurbs
Could you connect the filter/router directly at the little test socket?
Message 13 of 19
We haven’t looked before; this is what was under the faceplate
Message 14 of 19
Hi HBurbs
There may be a test socket underneath the face plate (if the lower section comes away when the screws are removed)
Have you ever checked this?
Message 15 of 19
Hiya,
we don’t have a landline phone so can’t comment on voice service.
No test socket; I’ve attached some photos so you can see the setup.
Message 16 of 19
Thank you. I've run a test on the line now which hasn't detected a fault, however I can see a few re-connections on the line. Is the voice service ok with no noise? Does your main socket also have a test socket please?
HBurbs
Visitor
Message 17 of 19
Hi Michelle,
I’ve added that information to my profile.
thanks!
Message 18 of 19
Good afternoon,
  • Name
  • Telephone number
  • Alternative contact number
