on 30-04-2024 10:40 AM
Hello. For the last few weeks the Wi-Fi has been resetting itself from channel 6 or 11, back to channel 1 which is what my neighbours router is set to. This is causing the 2.4ghz to drop out which is affecting my smart plugs and thermostats, also my Ev charger which is set to charge on off peak times. Is it possible to update the software or lock the channel to the desired channel.
Thanks for any help
yesterday
Hi Nobag
I'm so glad to hear this, thanks for letting me know 🙂
yesterday
Hello , Thanks for getting back in touch, the new router has arrived and installed. The new router would not connect at first because there was a fault with the line, which your people cleared and everything appears to be working fine at the moment. The 2.4 Ghz has not dropped out since the new router was installed.
I will send the old router back next week.
Thanks for all your help.
yesterday
Hi @Nobag
Our faults escalation team have advised that this fault has been resolved.
Is everything working ok now?
Thursday
Hi Nobag
Have you spoken to the team since my last post?
Tuesday
Hi Nobag
I've escalated this and asked the team to contact you ASAP.
Tuesday
Yes, I have taken the cover off and plugged it into the test socket.
Tuesday
Hi Nobag
I'm so sorry to hear this.
Is the new router connected at the test socket at the moment?
Tuesday
Hello, Thanks for getting back.
They have sent me a new router which I have connected, but unfortunately all I can get now is a flashing orange light.
I reconnected the old router and same thing, flashing orange light. I logged onto the router admin page and it says no internet connection. I am connected now using my phone as a hotspot.
Monday
on 10-05-2024 10:40 AM
Hi Nobag
Are they contacting you today? (this afternoon)
Have you seen any improvements to the connection?
on 10-05-2024 10:36 AM
Hello, Yes they have been in touch and have reset the router on their end to see what happens and have said they will be in touch again on Friday afternoon to see if it has made any difference.
on 10-05-2024 07:37 AM
on 08-05-2024 09:54 AM
Hi Nobag
I've asked the team to contact you so they can investigate this further.
on 08-05-2024 09:49 AM
Yes Please.
on 08-05-2024 06:56 AM
Hi Nobag
I think we should ask our faults escalation team to take a look at this. They will also contact you to discuss this further.
Would you like me to arrange this?
on 07-05-2024 05:52 PM
Hello, Thanks for the reply. Unfortunately the same same thing is happening.
I put the router onto channel 6 or 11 and it works fine.
Until some time overnight it reverts to channel 1 and then the 5GHz works, but the 2.4GHz is lost.
I then have to reset to channel 6 or 11 and reboot the router. (my neighbours router is on channel 1)
I don't know what is causing the router to change channels, but If the the channel could be locked on 6 or 11. I think it would be more stable.
Thanks Again
on 07-05-2024 09:26 AM
on 03-05-2024 08:37 AM
Hi @Nobag
Apologies for the delay. Can I just confirm, is this still happening since my last post?
on 30-04-2024 10:49 AM
Ok thanks for confirming. Leave this with me and I'll come back to you shortly.
on 30-04-2024 10:46 AM
Hi, Thanks for the response, I have to reboot the router every day to get the 2.4ghz working again.
